Post Catgories
Tags
This is another huge release with some really tasty new goodies, including:
  • HttpListener Support – You can now turn your Meadow into a web server with HttpServer.
  • TextDisplayMenu – Meadow.Foundation now has a new library called TextDisplayMenu that allows for easy menu creation and interaction.
  • Antenna Switching – We’ve exposed an API to switch between the onboard and external antenna.
  • Battery Voltage – You can now read the battery voltage from Meadow.OS.
  • Better Connection Errors – Failed WiFi connections will now give more information.
For more details and to upgrade, check out the release notes.
